- Mar 2, 2022
- 58
- Plaster
- Pentair Intellichlor IC-40
This is what my panel currently says:
Intellichlor
Enable: Yes
Pool Mode: 30%
Spa Mode: 1%
Super Chlr: Off
Run Hours: 0
Currently, my chlorine is 0 when I test it (I've added bleach a few times this winter). My outside Intellichlor shows a red light that says "Low Salt". Can you tell me what each of these means and if they are set correctly? If not, what should they be set to. We only got a couple of weeks of swimming last year before it got too cold. I want to believe the pool company cut the salt down since it was producing a lot of chlorine. The last few days, we have had warmer weather with the pool temperature today is 65. I don't want it to turn green. I tested my salt this morning, and I have 1800 ppm. How much salt do I need to add? I'm assuming that just by turning up the pool mode % when it says low salt, would not help. Can someone tell me what each of these mean? Also, if you put Super Chlor to the "ON" position say after a party (is that when you use it?), how long do you put it at that?
Thanks for any help you can give me to help me understand my SWG.
LaDonna
Intellichlor
Enable: Yes
Pool Mode: 30%
Spa Mode: 1%
Super Chlr: Off
Run Hours: 0
LaDonna
