Hello,
I have a new pool, it is about 240 square feet.
I have 200 safest of solar and a pentair variable pump. What gpm should I set the solar to.
What gpm would you recommend for the gas heater?
Today is 71 degrees and the solar has been only adding 1 or two degrees at 20 gpm after running from 10 am to 12.
I would like the pool to be at 82-86. It seems like the solar is not designed to do that. Thank you in advance
