Hello,
I have a semi-in ground Doughboy Pool, with the deluxe skimmer etc. I am needing to replace the gasket on the return jet and skimmer. However, idiot me was in a hurry and didn't take to much time to really look at how it was installed prior to taking it out
Does anyone know if this gasket goes on the outside of the vinyl liner, sitting on the liner, through the hole and then the other side of the gasket is sitting on the outside of the pool wall? Then the return jet goes through the hole, so inside the pool it is on the gasket, and outside of the pool the other piece is also on the gasket, smashing the gasket onto the liner and pool wall? Attached an image of the gasket etc
