- Jul 4, 2012
- 801
- Vinyl
- CircuPool RJ-60 Plus
All right, I am replacing the 30’ AGP I inherited with this house with another 30’ (currently in boxes in my garage) so decided it is also a good time to upgrade to SWG (purchased Circupool RJ 60).
Now I need help in thinking through what I need for electrical upgrades and how to incorporate my SWG into plumbing. Equipment pad area (such as it is) does not have many limitations, see pics. I wouldn't move the gas heater, but am moving the electric to accommodate a larger shed. Current plumbing is flex PVC that is disconnected and brought in for the winter, along with pump and cartridge filter which sit on their own hayward plastic base.
I will be hiring an electrician but want to educate myself so I know what to ask for and have a basic understanding of how it all works. I am figuring I will have to do the plumbing myself so interested in learning some new things as I have not worked much with PVC in my life (outside of disconnecting and reconnecting my plumbing the last 10 pool seasons).
Current equipment:
2 speed 1.5HP Hayward pump
Raypak heater 406A natural gas
Cartridge filter (150 Sq Ft)
Aqualuminator (AGP return light, 3 prong plug)
Dolphin cleaner
SWG (new)
Current electric is standard 2 receptacle GFCI outlet, everything plugs in using a regular 3 prong plug. Pump plugs in through a digital timer for daily operation.
What do I want out of my system? Simple is a good start. I would like my pump and SWG on a timer, no need for the heat to be on a timer.
Questions:
· What kind of timer - one of the intermatic models? Any recs or specs I should focus on?
· Can my pump be wired such that hi and low run times can be programmed in or is that always a manual flip of the switch? (This isn't really critical - I only use high speed when running the heater which I always turn on manually)
· How is the SWG wired to the timer? I've been reading that I want to ensure that the SWG cannot get power if the pump cannot get power so do I just ensure the SWG on timer is always set inside of pump run time?
· Will the addition of the SWG and timer require any upgrades to electric that runs from house out to pool?
Fortunately the electrician specializes in pool and hot tub electric which is not that common around here.
I'm going to have things bonded as well.
Can the bonding be done in a C rather than the full loop? I have some concern about having space for a person to crawl under the deck and dig/bury the copper wire.
For plumbing the SWG do I just cut my flex pvc return line a bit after the heater and splice in the swg? From the pic, the suction and return lines run against the bottom wood step where pavers meet it, and then go under stairs to reyurn and skimmer, but I can change that if there is a better way.
Thx!
Paul
Current equipment:
Dolphin cleaner
SWG (new)
Questions:
Thx!
Paul
