Hello. I just refilled my pool. All readings are within limits after addition of necessary chemicals ( Calcium chloride, Stabilizer, granular chlorine). My pool is 16000 gallons. My readings are as follows:
FAC - 4 ppm
TAC - 4 ppm
CH - 200 ppm
CYA - 50 ppm
TA - 100
pH - 7.5
TDS - 200
Pho - 50
I am using liquid chlorine ( 12%) purchase at Pool Supply store. I add to reach FAC of 4 ppm. My question is after adding liquid chlorine , in 1-2 days it drops to maybe 2 ppm. Temperature is in the 80's. The pool store that I buy from also does pool servicing and says they only service pools once a week which is the norm. My chlorine level will be down to 1 ppm if I go a week without adding chlorine. How do I make the chlorine level last a week at good levels? Am I doing something wrong? Also he uses stabilized chlorine tabs in residential pools during the summer/spring months in addition to liquid chlorine. then no chlorine tabs in the winter. Is it okay to use both at the same time? I thought you shouldn't mix different types of chlorine?
I wanted to go back to using triclor stabilized chlorine tabs only but he says "NO" because of increasing CYA levels, which I understand but it is a headache having to add liquid chlorine every 2-3 days. Any advice?
FAC - 4 ppm
TAC - 4 ppm
CH - 200 ppm
CYA - 50 ppm
TA - 100
pH - 7.5
TDS - 200
Pho - 50
