Hello was wondering what the recommend set numbers I should go for when it comes to the chemicals in my pool I keep testing it but the trouble free pool app I have has a target range and not a set number. And I was wondering if there is a set number to aim for for my pool size. My pool is 4440 gallons above ground intex pool with a 2500 gph pump on it that I run 24/7. I had my pool tested at the pool store yesterday and the numbers they were giving me was way different then my liquid test kit that I have plus their target numbers are way higher then trouble free pool apps so was wondering if you guys could help me set some straight forward numbers and not ranges to aim for.
I attached the papers the gave me at the pool store tell me if the range numbers make sense or not please.
