- Jun 3, 2018
- 41
- Vinyl
- Hayward Aqua Rite (T-15)
Hi everyone, I had started a similar thread about test kits but I guess I need some general help with my new switch to SWG from chlorine so I’m starting this thread. The new SWG pool is a vinyl liner with about 20,000 gallons, DE filter and Hayward TCell 940 w/ Hayward AquaRite 900.
New water got filled and I’ve been running the pump 24/7 past few days slowly adding salt and am also currently doing the sock method for CYA. And I got my 1766 kit last night so I tested this morning. So right now I’m at:
Salt - 3,300 (overshot a bit as manufacture recommended 3,200 but it’s still in OK range)
CYA - 25-30 and I’m still adding via sock method. What is my ultimate goal for CYA, 70?
FC - .5. (I added a little liquid chlorine to get some in the pool, but I have a question about this going forward)
pH is good
My main questions are on how do I work this SWG going forward. At this stage do I need to add liquid chlorine per the FC/CYA chart and let the SWG maintain or I thought the SWG generates chlorine? I’m not sure what percentage to put it on, and do I run chlorinater the entire time the pump is running? And then what, if anything should I test to make sure it’s running where it needs to be, FC? Thanks to anyone in advance who has input as I tackle this new learning curve.
pH is good
