I have an 18x36 in-ground which we did not open last year. As I pull back the cover I found that the liner has pulled away from the shallow end wall and there is air between the wall and liner. (see photo) Will this stretch back? The liner is about 8 years old. Do I need to vacuum the air out as I fill it?
Any recommendations on what I need to do would be appreciated!
Thanks in advance....
