Help understanding logs, pls
stretchphoto
166
Champaign, IL
Hayward Aqua Rite Pro (T-15)
These reading seem erratic.
I think the jump in pH was caused by previously using some possibly dated reagent.
FC slam levels just keep going up.
TA indicates need for baking soda.
Advice on how to continue?
Temps here in central IL have been cool. Lows in the mid 30’s. Highs 50’s.
Pool water is ever so slightly cloudy. Still working to get the winter silt out.
pH testing is not accurate above FC of 10.
Your CYA is super high, which is the source of your problems. If I were you, I'd dump 60% of your water and start with a fresh fill.
SLAM from there and you'll be in a much better spot.
Make sure to log a complete set of information when possible. Just doing some tests from time to time makes it a bit harder for us to help.
Reactions: Mdragger88
It's your choice, for sure, but your CYA is unmanageably high. You will waste a lot of money on chlorine and not end up with clear water.
Your water replacement is likely much cheaper than the chemicals and time you will waste.
Thanks. I do appreciate your advice.
Not sure why that cya jumped overnight. Either we were misreading it prior or I misread it this morning.
Going to keep monitoring for now.
Rain coming tomorrow. Planning to vac after that & will go from there.
Thank you for this.
But 60%???
I think I’ll wait on that, at least for now.
No algae. Clearish water. Seems drastic to me.
Why are you adding cya? This increases your necessary slam level
Clearish = algae
Slam fc level for a cya of 100 is 39ppm
It is impractical to slam a pool with a cya over 80ppm.
Do an
Overnight Chlorine Loss Test to confirm or deny algae although cloudy water & dead algae on the floor count as visible algae.
Reactions: stretchphoto
Passing oclt is great 👍🏻
do you see any visible algae (dead or alive)?
Is the water still cloudy?
If either of those are true you should keep fc at slam level for your cya until they are no longer true.
