Help!! Unable to brush off even 4X shock
kchan831
1
ny
opened pool last Sunday and this hasn’t done over. Water tested every other day at Leslie and ph and TA and other numbers are in range…very high FC since I’m shocking it and run filter 24/7… still hard to scrub and unable to get it off… no copper and iron in test
Reactions: silversteed
Welcome to TFP.
Would you like to use TFP Methods instead of Pool Store methods to clear your pool?
If so, you need your own test kit. Either the Taylor K-2006C or TFT Test Kits
Stop adding shock and add 5ppm to your pool daily with liquid chlorine until you get your test kit.
Then you need to follow our SLAM Process
Your choice.
