Were thinking about a SWCG with a chlorine backup system. What should the extra chlorine part cost?
I don't think there is any need for a chlorine backup system. They are probably talking about a chlorinator, which uses the pucks. You want to avoid those because they add CYA to the pool. They are useful when you are on vacation to make sure your FC doesn't go below adequate levels, but not worth the expense just for that. Just get one of those floating puck dispensers to use when you are away for more than a few days. The only other chlorine automation is a stenner pump which uses a liquid chlorine tank to pump in chlorine on a given schedule. But that is not practical or cost effective as a backup system.
