Hey everyone. I am new to proper pool ownership (second season pool owner...last year just threw shock and chlorine tabs at it)...I am using cheap HTH test strips and have found that my alkalinity and of course PH levels are off the charts. I dumped 1 gallon of muriatic acid in it and tested after a few hours with the pump running. It did not decrease. I dumped a second gallon in and still no change. I have ordered the TF-100 test kit and it is on its way, but says it won't be here for 1 week. I am calling on the experts. What do I do until l can get this tested properly? Kids are begging to get in the pool. My nearest pool center to test water is 30+ minutes away.
I am attaching a picture of the test strip, but I don't currently have access to the color chart on the test strip package, but they are HTH brand if that helps anyone. ** I know my chlorine levels are low, but wanted to get the alkalinity an PH in order before i dumped all the chlorine down the drain...
