Tried asking A Pro on poolfyi.com, but no response to date. Does anyone have experience seting up this combination, particularly the CO2?
Eventually connected my Intellichem, Intellichlor and CO2 injection system, however I'm unable to confirm with the CO2 kit where to set the "MIG Meter" knob. the cylinder valve is fully open and shows just under 1000psi. With the MIG Meter off, the needle has gone all the way around the manometer and is resting against the stop. I have seen injection of CO2 once when the solenoid iced over and what I assume is a relief valve opened blasting CO2 into the atmosphere. Have been unable to find any installation manual for the CO2.
Presently the Intellichlor has all green lights and is set on 60%, however over the last 3 days pH has risen from 7.6 to 7.9 and ORP has dropped from 750 to 645.
I have set the Intellichem twice with the Auto Setup Wizard, which I understand will, based on the pool size (42,000Gals), automatically determine both CO2 injection time and Intellichlor discharge, plus mixing time.
When the system started up the water was balanced, I'd appreciate any help to ensure the system is set up properly.
p.s. The Intellichem flow meter only registers flow with the Intelliflo pump working at speed 3 or greater, although supposedly it only needs 25gpm, less than speed 3 and the magnet doesn't close, is this typical?
