Hi all I have a very green pool and since the 1st step in slam process is making sure your filter is working properly. I decided to replace the diverter because like and idiot I ruined the gasket last year by moving the valve with the pump on. Didn't read instructions previous own gave me. After replacing diverter I have water leaking out the backwash port when its in filter mood. If I switch to backwash nothing comes out backwash or return to pool. Same goes for most of the other positions except for rinse which nothing comes out backwash port and water does run through the return to the pool. Do I have the diverter on backwards? It seemed like it went only one way. Full disclosure I did replace the sand in the filter earlier this year. Filter never seems to actually filter if I suck dirt off the bottom of the pool I can watch it come through the return. The Laterals seem in good shape when removed the sand. I filed it with water 4 or 5" before adding the sand and made sure to not get any down the pipe. Sorry for the rambling but trying to give a complete picture so I can get some help.
Thanks
Jason
Thanks
Jason
