Well in fact the supplier has been awesome. I spoke to them about the guy refusing to fit a pressure gauge and claiming they're not supplied with one, and they sent me the relevant parts FOC. I'm 100% convinced the problem is with the guy who installed it rather than the product.Try pulling a hissyfit! Go after the manufacturer, demanding your $$ back for a new product that won’t work. As a bluff!
They have resources to help resolve this! I was in the service industry my whole life and have found, being completely unreasonable and loud- at first- is a very productive tactic! The screaming and yelling will immediately move you up the power structure. As soon as you reach someone with knowledge/power you apologize and plead your case! More than likely you will gain an ally.
I've now managed to get it running, I think. I did another very quick backwash and rinse, during the rinse I noticed the water all of a sudden was up into the dome, so I quickly switched the pump off and back to filtration, bled the last of the air out and now seems to be running OK-ish. "OK-ish", because it remains full of debris floating about in there, and there's a sort of rattling noise from the pipes between filter and multiport (can't exactly pin down where) that *could* be movement of water but sounds more like gravel or something rattling around in the pipe.
I have a different pool guy coming to take a look at it on Monday next week so with luck we can limp it through until then.
