Okay! I will wait for sun to re-test the CYA! And Heikejohn, thanks for the recommendation of re-using the water in the test tube to pour & re-pour. That makes total sense - my head is so jumbled I didn't even think of that!
Max2k, using the SLAM article shock chart, I thought my recommended shock FC level was 24 since I have a SWG (albeit non-functioning at the moment). Is that incorrect? Of course, that was also when I thought I had a CYA reading of 60 from Leslie's. If my CYA really is less than 20, I guess that will dramatically change the recommended FC level? The chart doesn't address SWG pools with under 60 CYA.
If I re-test in the sun and the CYA is truly low, do I add the cyanuric acid during SLAM or do I wait until SLAM is completed? Also, is there a downside to using liquid as opposed to granular other than it being more expensive?
The first OCLT was conducted this morning at dawn, but I'm unsure if it might have been affected by rainfall (it rained intermittently throughout the night). I don't know if my initial testing early yesterday evening was off at an FC of 15, but last night I tested the water before bed and the FC was higher than my initial test:
FC: 17
CC: 0.5-1 (I couldn't tell if the water "cleared" at 1 or 2 drops)
This morning:
FC: 15
CC: 0.5 (the pink tint definitely cleared at one drop)
Of course its just my luck that as soon as I get my test kit in along with a replacement salt cell, this particular region of Texas decides to act more like Seattle (and is forecasted to remain rainy for over a week)! Arg!
Kimkats, thank you so much for the links - I have seen/read/used them but to have them outlined like you have with suggestions to print/bookmark is very helpful!
Also, I got in the pool on Saturday & took out one of the lights (there are two in the pool) to scrub. There was a little bit of brown-ish algae/buildup on the back of the light fixture and it was scrubbed around the niche (black algae definitely came off around the edges). I wasn't able to get the fixture in the deep end off and I will wait until my husband & I can help one another (although the exterior & edges of the light has been vigorously scrubbed). Taking the light out was a breeze but getting it screwed back in was a task only because it was difficult to make sure that the screw lined up with the hole!
