- Apr 13, 2022
- 91
- Fiberglass
- Pentair Intellichlor IC-20
Hey! Hopefully someone can help out with this. I apologize in advance for any typos - my hands are frozen. Pool company came today and closed the pool. We thought about DIYing but just didn't have the time. I say that to point out that I had already researched and watched probably 100 videos about closing.
First - we have an autocover. They lowered the water to winterize and did not raise the water back up. I asked when they were done if I needed to refill (fully expecting a yes), and they told me no. Strange, but whatever. I figured I would just go peek in the pool, make sure everything is capped, and then add water to support the cover. Everything looked good until I opened the skimmer box.
Second, and my main issue - the gizzmo looked crooked so I just lightly touched it to make sure it was installed. It popped right out of the hole. I see that the line is completely pink with antifreeze, so that's reassuring. However, the gizzmo will not go in the hole correctly. The hole has the lip from the bottom of the skimmer box area coming right up to the edge, and the right sized, threaded portion of the gizzmo isn't long enough to lock in. I have tried multiple times. It feels like it grabs just a bit, but any amount of touching knocks it right out. (I'll reply with a pic).
Obviously I need to fill the water back up to a point where water is going to be in the skimmer box and the gizzmo should be what is keeping that water from going back into the plumbing, right? Is there a different version of the gizzmo that I need? This is the same one that was taken out after the installer closed our pool last January, so I'm not sure if it just barely sat in there for the end of 2022 winter or what.
Also, should this have pipe thread tape on it? Because it doesn't.
Thanks!!!!
Thanks!!!!
