I have two skimmers , two returns, and a wall drain which is about 5 inches below the skimmers. Here are the measurements: Bottom of skimmer is 10" below the top of the pool, returns are 18" below the top, wall drain is 20" below the top. My pool is 42" deep in the shallow end and about 8' in the deep end.
At first, I drained the water to a few inches below the skimmers. Then I read that I need to keep going until it is all the way below the returns/wall drain. Is this necessary? In the past, a pool company has closed my pool but I'm doing it myself this year. They have never blown out the lines because my pump system is downhill from the pool, and I'm guessing that causes the water to drain out of the lines. I live in Alabama - we do have freezing temps over the winter but usually nothing drastic. In past closings, they would put gizmos in the skimmers and plug the returns.
I went ahead and drained down almost to the wall drain but this seems so low! I do not want to risk damaging my vinyl liner. Right now the water level is 18" below the top of the liner. So there is 24" of water in the shallow end. I am concerned I dropped the level too low.
