PB # 2
GENERAL SPECIFICATIONS
SWIMMING POOL:
Pool Type: Shallow Pool, Spa and Water Features
Overall Size: 13’ x 48.5’
Pool Surface Area: 450 s.f. Square Feet
Pool Perimeter: 123 Lineal Feet
Pool Depth: 3.5’ to 5’ to 4’
Average Depth: 4.2’
Pool Capacity: 12,000 Gallons
Piers: 8 Helicals –see options - Will cost extra
SPA:
Spa size: 7’ x 7’ inside
Spa Area: 49 Square Feet
Spa Perimeter: 28 Lineal Feet
Spa Depth: 3.5 Feet
Spa Elevation: 12” raised from pool
Spa Capacity: 500 Gallons
MATERIAL SELECTIONS:
Pool Coping: Travertine – 18” wide
Ceramic Tile: 6” at pool perimeter – standard tile at pool
1” glass tile at spa wall
Decking Area: 300 s.f. Rpck Salt Colored Concrete
Drainage Line: 4” underground as needed
Interior Finish: Colored quartz
EQUIPMENT:
Circulation Pump: Pentair Intelliflow VS + SVRS
Filter: Diatomaceous Earth 60 s.f. w/ multiport valve
Sanitizer: In-Line Chlorinator and Salt System
Automatic Cleaner: Pentair Racer w/ pump
Control Valves: 2” x 2.5” Never Lube
Pool Light: 2- Globrite LED Color
Spa Light: 1- Globrite LED Color
Gas Heater: 400K BTU Electronic Ignition
Air Blower: 1.5 hp Silencer
W/F Pump: 1.5 hp Whisperflo
Laminars: 3- Color Laminars
Maintenance: Telescopic Pole, Brush, Net and Test Kit
ELECTRICAL:
Wiring: All proposed equipment
Bonding/Grounding: #8 bare copper wire
GFCI: At equipment for pool lights
Controls: Easytouch electronic controller w/ screen logic
Freeze Protection: On all circulation pumps
PLUMBING:
Suction Outlets: Skimmers- 2” line
Dual Main Drains – 2” line
Return Inlets: 4 wall returns
Backwash Line: To grade – 2”
Fill Line: ¾” automatic
Overflow Line: 2” gravity to lower end of yard
Spa Drains: Channel Drain – 2.5” line
Spa Jets: 6 at bench – 2” line
Spa Overflow: 2” line
W/F lines: 2” suction, 1.5” returns
Gas Line: From Meter to Heater
SPECIAL NOTES:
The following items are not included as part of this contract:
- Electric, water and gas at equipment pad by owner
- Fencing and Safety as per city code
- Landscaping and Irrigation
GUARANTEES:
5 YEAR ON STRUCTURE: PB warrants that the pool structure will remain structurally sound for a period of five (5) years from the date of installation (plaster) The term structurally sound means that the swimming pool is capable of retaining water, and in the event of failure to do so within the stated period, PB will repair the structure so that it will retain water, without charge to the owner, upon written notification of such defect.
THREE YEAR ON EQUIPMENT:Filter, pump, electronic controller and heater carry a 3-year warranty from the manufacturer.
ONE YEAR ON ALL OTHERS: All other features including coping, tile, plaster, plumbing lines, electrical, and accessories, are guaranteed against defects in workmanship and materials for twelve (12) months.
LIMITATIONS AND EXCLUSIONS: The above-mentioned warranties are to insure proper installation, workmanship and function of the swimming pool. In order to keep this warranty in effect, owner must continue routine pool operations and maintenance in accordance with the Pool Owner’s Manuals and Manufacturer’s Instructions. BP is not liable for any defects or damage caused by improper pool maintenance, negligence or misuse.
PRICE: PRICE BREAKDOWN:
Permits and Plans $ 1,000.00
Pool Structure & Equipment $ 54,000.00
Spa Structure and Equipment $ 11,000.00
Color Laminars and Equipment $ 4,000.00
Electronic Controller $ 2,500.00
Pool Decking and Drainage $ 4,500.00
Plaster care
$ 500.00
Total Value of Improvements $ 77,500.00
Options: Plaster Upgrade - Pebble $ 2,000.00 _____
Helical Piers(8 recommended) $ 4,000.00 _____
