Well here's an update. Keep in mind I have been adding MA for 6 days now , everytime pH drifts up to 7.8-8.0 and bringing it down to 7.0 or 7.2 each time, aerating, etc.
FWIW, I can -easily- see the green to pink color change now... though i still verify it every time with my digital pH meter to make sure I hit the 4.5 reading mark with the exact drops.
Current numbers from this evening:
FC 8.0
pH 7.6
CYA 70
TA 90 (it took 13.66 gallons of MA to reach this level over the 6 days, aiming for 50)
CH 250 (waiting on bumping this up until I check my auto-fill water CH value)
Since this thread was originally about TA... it's gone from what I suspect was around 270 to 90 over the last 6 days. I have to add considerably fewer drops now to the TF-100 TA test, and I can even do it without the x25 multiplier and stick to the x10 multiplier (9 drops last time!). So I'm making big progress.
pH still going up on its own quickly, but I've been running water features a ton lately to help aerate. With a disappearing edge drop, 2 bubbler/beach-jets , a water slide, and 2 big waterfalls, I suspect my pH will be very hard to manage if I use the water features regularly, so I'm *AIMING* for a TA around 50 in hopes that will slow down the overall pH rise. Am I correct in this that pH should rise slower at a TA of 50 compared to a TA of 270'ish like I probably had 1 week ago?
(I may also look into Poolsmith CO2 injection, to help combat my water features, although it won't help with my 400 TA auto-fill, -sigh-)
