- May 17, 2017
- 37
- Plaster
- CircuPool RJ-30 Plus
Keep the tabs.
So far so good! How do you like that solar heater?Hope you’re loving it. I just installed a Jacuzzi SWG. $1500 +\- and took about 1 hour install PVC and electrical. BEST purchase of the year. Easy maintenance and feels great.
I am using my solar heater right now as it is starting to heat up in AZ to keep the pool a comfy 87 so my pump is running little longer than I normally would have it set.
Love the solar. This is our first summer in this house, and we’re finding we get probably a extra 1-2 months of swimming on the front and back end of the season. I am able to maintain 87 degrees no problem. It drops at night here in North Phoenix but by 12 I can get it up over 90 no problem especially after this weekend. I got it to 90 yesterday at 1 but turned it off because it was way to warm. I’m curious on the cooling function it has too.So far so good! How do you like that solar heater?
I raised my CYA from 50 to 80 yesterday.
Started with FC at 8ppm yesterday before powering on...started SWG system at 20% and after about 4 hours it had already raised FC to 9ppm. Turned it down to 10% around 2pm yesterday, and this morning I'm now at 10ppm. I left it there for now...will test again tomorrow morning and adjust down to 5% if necessary. I've been running my pump 24/7...maybe have to switch it off sometimes if 5% keeps raising my FC too. I guess that's a good problem to have
