Hey guys!
My name is Drake and I just bought a house with a roughly 16x32 vinyl liner in-ground pool...approx 20k gallons. I have never owned a pool before. The pool hadn't been opened all summer until I had it opened during the inspection. It was somewhat green and very dirty.
Since then, I had the previous pool guy show me how to use the pump/filter/etc and walk me through some basic pool maintenance...he tested water and told me to add 8lbs baking soda that night , and then 4 gallons of 12.5% liquid chlorine the next day...both of which I did.
The pool has cleared up a lot and i have vacuumed 95% of the dirt out (mostly to waste). I decided today to go to Leslies and get a water test done (I will order a good test kit today) and these are the results:
FC: 0
TC: 0
CALCIUM: 210
CYA: 0
Alkalinity: 50
pH: 7.4
Copper: 0
Iron: 0
TDS: 800
Phosphates: 300
Chemicals I have on hand:
20lbs 3" tabs
1 bottle of FLOC
4 gallons 12.5% liquid chlorine
6 lbs of stabilazer
Chemicals in pool now:
4- 3" tabs in skimmer basket (i ordered a floater-will be here Wednesday) [the pool has an in line chlorinator but the pool guy said it hasn't worked in years..haven't looked further into it]
The guys at Leslies wanted me to buy $100's of dollars of chemicals and but like 25lbs of stuff into the pool.
So what should I do? Its only going to be swimmable weather for another few weeks at best so I don't want spend several hundred dollars if I could avoid it.
FC: 0
TC: 0
CALCIUM: 210
CYA: 0
Alkalinity: 50
pH: 7.4
Copper: 0
Iron: 0
TDS: 800
Phosphates: 300
20lbs 3" tabs
1 bottle of FLOC
6 lbs of stabilazer
