Help me, I've lost the fight with Algae
May 29, 2012
19
Hi fellow members,
I've been maintaining my own pool for over 12 years, with not too many hassles. I'm in NJ, and it's an I ground pool, 14x33 rectangular, 23,183 gallons as per calculator.
Least season I didn't cover the pool, and was very late in closing the pool, and lowering the water below the skimmer line.
My usual opening treatment of merely throwing in shock hasn't had any effect on the extreme algae that I have. I've gone through 28 1 lb bags of Shock in 3 weeks, and the water looks as green as ever.
Last week At the advise of pools store I added a 4lb contained of green to clean, followed by 2 lbs of shock at 12 hr intervals, brushed the walls and floor, still no change.
I've had me filter apart 3 times due to the grids clogging with algae, clogs up in a matter of 4 hours.
My gauge shows 0 pressure, I bought a new one. I'm currently running on recirculate, as per the advise of pool store, since the filter kept on clogging.
The water seems to flow well in recirculate mode, and no clogging. My pool chemistry is all wrong. I already picked up Unscented Clorox 6% bleach and Arm & Hammer baking soda at Costco. I have to pick up Cyanuruc acid, and Borax.
I wod appreciate any help. Thankyou.
I bought a Taylor test kit, and did some tests. I will post below.
Please forgive for my posing errors, as it's my first time doing so many tests.
FC(free chlorine) is less than .5ppm R0001, & R0002
TC R0003 is 4ppm (bet 3, & 5 ppm)
CC = 4
PH = 5ppm (very yellow, much less than 7) with R005
Still very yellow after adding R006
Alkalinity
2 drops R0007
4 drops R0008 to turn red
40 ppm alkalinity as calcium carbonate
Calcium Hardness
20 drops R0010
5 drops R011L made it pink
20 drops R0012 made it light blue
200 ppm calcium hardness as CALCIUM CARBONATE
CY acid
Less than .5ppm CY whitish cloudy color
cannot see black dot from top, only visible from front
:wave: Welcome :wave:
What was the brand or in the bags of white powder (we do not use the S word as a noun here) that you kept throwing in?
The key to knowing a path forward is the CYA test ... and what you wrote does not make sense ... thinking you did the test wrong.
Try reviewing this: extended-test-kit-directions-t25081.html specifically the post on the CYA test.
EDIT: I am also guess you bought the K-2005 test kit ... your really need the FAS-DPD chlorine test that is in the K-2006 kit. Luckily you can order the FAS-DPD test separately (see tftestkits.net) and then have a full set of required tests.
81330 shows the DPD Complete Test kit online. NOT the FAS-DPD. How do you test the chlorine? You use a powder for the FAS-DPD test.
81329 is the FAS-DPD Service Test kit and that would work great ... surprised someone found it locally.
You need the FAS-DPD chlorine test. I think that is the only difference. You can get it separately online (tftestkits.net is one source).
The problem with the chlorine test you have is that if only goes up to 5ppm. Looking at the the Chlorine CYA Chart you can see that while shocking your pool, the FC level may need to be maintained above 30ppm depending on you CYA level
Welcome, and if you have already added CYA stabilizer it can take a week or more before it shows up on the test kit, so if it has been less than a week I would suggest waiting and retest once it has had time to show up, better to be low and add a little than be high and have to drain water and replace it.
Also the pH test only registers down to about 6.8 anything less will test at about 6.8, before doing anything else you will want to get your pH in the right ballpark range, then you will want to shock with liquid chlorine / bleach, once that is done you can address your CYA balance.
linen said:
What is in the "bags of white powder"?
As jbliz said earlier your cya test of 0.5 makes no sense to us...could you explain how you did it?
White bags is shock.
Cyanuric Acid Test as per instructions
1. Rinse and fill CYA bottle to 7 ml mark with water to be tested.
2. Add R-0013 to 14 ml mark. Cap and mix Gordon 30 seconds.
3. Slowly transfer cloudy solution to small comparator tube until black dot on bottom just disappears when viewed from top.
4. Read tube on back of comparator block. Record reading as ppm cyanuric acid.
Thanks, I just realized what I did wrong, I filled the comparator with the cloudy solution, instead of adding what is enough.
I will test again now.
You keep saying shock, the problem is different companies sell different chlorinated chemicals and call them "shock" most common are Dichlor and Cal-Hypo, but could also be trichlor or lithium-hypo any one of which may also contain copper based algacide.
3.5 is a problem as the scale goes from either 20-100 or 30-100 (CYA measuring tube with full and dot just disapears will be either 30 or 20, depending on the size of the tube), higher number will be when dot disappears with less cloudy water in the tube, it can be poured back and forth to get a good reading.
28 lbs of dichlor, the stuff you used, should have raised your cya level by ~80 ppm.
You can not use the cya test kit and get 3.5 ppm cya, the kit can't really test below 20 ppm cya. As you fill the tube, the higher you fill the lower the value. To get 20 ppm, the comparator tube should be almost full.
Sorry, it looks like you have been pool stored, with that much CYA it will be nearly impossible to get enough FC in the water to kill the algae, you will likely end up having to drain at least half your water to get CYA down to an acceptable level where you will be able to use liquid chlorine / bleach to kill off the algae.
Thanks, I was ready to drain all the water. But the pool store guy said, "oh don't do that, if you can get water to circulate you can kill of the algae."
Should I drain it all then? Surely there is rotten leaves at the bottom.
