- Oct 9, 2023
- 2
- Plaster
- Liquid Chlorine
Hi all! I really hope someone can help me identify what all the valves are and how they should be set and hopefully the VSF pump settings. This is my parent’s plaster in-ground pool installed in December 2019 in California. Use the Clorox XtraBlue 3" Chlorine Tablets in float. Use a bubble solar cover to keep temperature comfortable at ~90° for my Dad to swim laps. Dad is blind and they are in their 70s so I want to label them REALLY BIG and clear. Unfortunately builder only labeled 7 pipes (the white words on the picture) and have no clue what the others are for. Honestly, valves #1&3 (yellow) are the only ones that get turned to “spa” for the spa jets. The vacuum is always plugged into the side suction. We are trying to get the VSF set right as the installer had him set it at 3200 RPM for 4 hours daily not utilizing the efficiency. I recently started researching on here for how to set the variable speed but when it gets below 2,800 the PoolCleaner wheels don’t revolve as much as it should and hardly sucks and he gets yellow on the walls. So don’t think it or valves are set right. Currently set at 2,800rpm 9am-1pm, 2,050rpm 1pm-4pm then 2,850rpm 4pm-5pm.
Thank you
Dec 2019 IG plaster 18k gal Clorox XtraBlue 3" Chlorine Tablets
Pool 4 drains (2 bottom, 2 pump side wall) [blue X]
Spa 2 drains [blue X]
1 skimmer [green Y]
Water feature (waterfall side pool) [red line]
Side suction vacuum [yellow O]
Pool returns 4 [pink arrow]
18K gal, IG plaster, 1/2 hp Pentair IntelliFlo VSF pump, Pentair 1/2hp whisperflo high-performance pump for spa and water feature, Pentair MasterTemp 400 high performance heater, Pentair SolarTouch Solar Control System, 520sqft Pentair Clean & Clear Plus cartridge filter, Hayward The PoolCleaner 2 Wheel Suction Cleaner, Poolmaster #22260 5-Way Test Kit
Thank you
1 skimmer [green Y]
