I have narrowed my heater selection down to the following two heaters.
1. 460775 Pentair MasterTemp 400K BTU Natural Gas Heater ASME
2. 009997 Ruud P-D406A-EN-C 399K BTU Natural Gas Heater Electronic
Are there some heater experts that can guide me as to which heater I should select and why? I will be incorporating this heater with an IntelliCenter automation system and so I will just be using the fireman's switch in the heater for on/off automation control. The Pentair heater is $380.00 more than the Rudd. The heater will only be used to extend my swim season since I reside in southern Arizona. The pool size (no spa), is nearly 12,000 gallons.
Thanks in advance for any insight that some of the resident heater "guru's" here might be able to provide!
