Hi there... I have a 30k pool/spa combo that has one pump which has failed. I need to replace the pump and was thinking of using a variable speed unit. My concern is that when I turn the spa on, I want the speed to be higher than when it is just being used for filtering. I do not want to do this manually. Can this be controlled thru aqualink if I purchase a jandy VS pump?
Also, can you help me pick a pump??? We currently have a hayward Super II Pump 2.0 HP. Any suggestions on a pump??? I'm thinking this one???
www.jandy.com
VS FloPro 1.85 HP, 115v/230v Variable-Speed Pump | Jandy
A full-featured 1.85 HP variable-speed pump that delivers on price and value, the VS FloPro 1.85 is the perfect replacement for single-speed pumps up to 1.5 HP.
