Hi there new to forum. Need some advice! Somehow and I am not sure how but my CYA levels were through roof after only a week and a half of having pool up. Obviously I added too much stabilizer. Well we drained about 25% of pool to get level down. It was at 75 and now is about 50. Decided to use bleach now instead of pucks. After we refilled the pool, I tested water so we can get our alkalinity back in order. PH is 7.6, TA is 150, water temp is 84, free and combined chlorine is both 0. Here is the crazy thing put calcium hardness is so low that when I did the test with the Taylor test kit, it turned red right away. So I don’t even know how to read that. I didn’t even have to add drops to the solution to get it to turn red. What do I do? What is causing this? I used a lot of muriatic acid last week to get TA down. Could that cause it? Thanks for any help you can give me!
