It could be early signs of some internal icing in the filter. Unless you see something very obvious preventing water from flowing from the pump through your filter and to the returns, at this point it's probably best to shut everything down so that you don't damage your equipment. If you can, drain the water from the pump basket via the pump's drain plug(s), and also your sand filter if possible to prevent freezing (expansion) damage. Cover any exposed plumbing and equipment with a tarp or blanket - anything to help keep the bitter frost off of the pipes until this Grayson mess is over. Also try to protect your multiport and any 3-way valves as there have been a few of those showing some damage by other members.
Tomorrow, inspect everything in better daylight and go from there. Once the temperature gets up over freezing consistently, you can fill things up and test the system again. The pool water should be fine for a while with the cold temps.
