- Jun 12, 2011
- 3,767
- Plaster
- Pureline Crystal Pure 60,000
Open the pump basket and use a garden hose to run water into it. That way you can fill the pump basket and the lines all the way back to the pool. Close it then try starting the pump. If that doesn't work try leaving the basket open with the hose running into it, start the pump then quickly pull the hose out and put the lid on it. That sometimes works. You have a major air leak somewhere, it should be pretty easy to find once the pump is running. Smear shave foam anywhere you suspect. If that's the leak, you will see it disappear and it will show up in the pump basket. To confirm, wrap the area in plastic wrap and the leak will stop. I would bet that it's a connection you made when replacing the pump. The most obvious solution is also the most likely. Check those connections very carefully.
