Just pulled back the corner of my cover and saw there was no water in the shallow end. Bone dry except a small puddle toward the middle. Water remains in the deep end and almost all the way up the slope. Walls are all exposed. Some of the liner appears to have shifted in the shallow end. Liner remains attached around top perimeter as well as around stairs (although space has developed between bottom of stairs and liner like a taught tent) Water level is below all plumbing, light fixture, stairs etc. The only fixture still under water is the main drain.
My concerns/questions
1. Is the liner irreversibly damaged due to the severity of water loss? Can I just add water to correct the water level or do I risk making the problem worse?
2. Obviously there is a leak at or below the current water level. Should I find and resolve this prior to adding water.
3. Am I over my head and in need of a local pool company to come sort out the leak and liner?
Pool originally built in 1980’s.
30k gallon kidney shape. 9ft in deep end.
Current liner is about 5 years old.
Not sure what other info may be helpful but happy to add any needed.
Thank you!!!
Shawn
Thank you!!!
Shawn
