- Mar 28, 2021
- 8
- Fiberglass
- Pentair Intellichlor IC-15
My pool installer handed over responsibility for my newly installed pool about 2 weeks ago and I'm so very appreciative for this forum. Used TF100 kit to run all tests on Fri/Sat/Sun. Started Fri with CYA at 0, today at 75 so think that's a win! Based on today's test results listed here and Pool Math, I increased SWG from 20% for 40% to raise FC to target 5. I think I need to work on Calcium next since current level is 100ppm and I plan to get waterline tile installed in the next several weeks. Have municipal water supply.
Pool Math says add 24 lbs calcium chloride or 32 lbs calcium chloride dihydrate. The large amount is making me pause (and a little anxious). I've searched TFP site; are the following tips on target for my situation?
- get product as close to 100% calcium chloride as possible--> are there a few really good quality/price choices or is it mostly a commodity product? I've seen sooooo many names listed.
- bring pH down to 7.2 first?
- apply smaller amounts over several days, retesting each day?
- dissolve ~5 lbs/5 gal bucket of water and let cool?
- sling smaller amounts across pool with pump running--> turn off my SWG? how long?
- read ideal is 350-550ppm; should I aim for 450ppm?
Anything else I need to do? Thank you!
Build Type: Fiberglass
Volume: 7400 gallons
Latest Test Result Summary:
FC: 3.0 (3 hours ago)
CC: 0.0 (3 hours ago)
pH: 7.6 (3 hours ago)
TA: 65 (3 hours ago)
CH: 100 (3 hours ago)
CYA: 75 (3 hours ago)
SALT: 3520 (3 hours ago)
TEMPERATURE: 75° (3 hours ago)
CSI: -0.96 (3 hours ago)
