Hello,
I was here last month, trying to get rid of some stains on the walls. I'm still working on those with perpetual scrubbing. But I feel like a key to this solution is to lower my alkanity and calcium hardness.
Here are my numbers (Side note - I ran out of bleach yesterday, so my chlorine is currently at zero. Plan to get some tonight):
PH- 7.5
CC- 0
CYA- 45
CH- 800
TA- 180
I have been adding muriatic acid and my instinct is to add more. I also have a hose set up, so I've created some aeration. But I'm starting to feel like I'm going to have to hire someone to drain the pool to get down that CH. I read about "FLOC" but my pool is not cloudy at all. It is crystal clear. I just know that CH is supposed to be much lower.
I tested the hose water and it is 250 CH.
Is there anything else I can do other than partially draining the pool? If the water is clear, would that FLOC stuff work?
PH- 7.5
CC- 0
CYA- 45
CH- 800
TA- 180
