So our new hot tub (3 weeks old) had the water turn a light green tint with some foaming when the jets are running. Its a 500 gallon Jacuzzi 385 using dichlor/bleach method. Its city water not well water and the levels seem ok. Test results were:
PH - 7.4
FC - 2
CH - 220
CYA - 0 (only two weeks old)
TA - 90
Copper - 0
Iron - 0
TDS - 600
Phosphates - 500
Borates - 40ish (the color is hard to read) - from Boric acid
I get the same numbers using my testing kit (except for the copper, iron, tds and phosphates which I dont have a kit for). I shocked the tub yesterday with a non-oxidizing shock (potassium peroxymonosulfate) and ran the pumps for about an hour. I also cleaned the filters. The water is not slimy or cloudy - just a little green.
I normally add a tablespoon or so of dichlor after each use and used muriatic acid to get the ph stablized after about 4 days - now the ph does not move after using the tub.
The tub has an ozone system, UV system and the nature2 mineral in the filter.
Thoughts?
Thanks in advance for the help!
PH - 7.4
FC - 2
CH - 220
TA - 90
Copper - 0
Iron - 0
TDS - 600
Phosphates - 500
Thoughts?
