Hey there!
My husband and I are new pool owners and we’re not off to a great start!
I found this website after we already bought everything, so I’m trying to correct some things as quickly as possible. I’m currently slamming our pool because of light green/teal water and a CC of 1.5.
Our filter/sand was delayed being delivered and I didn’t add enough chlorine to start so here we are. Anyway, I’ve got SLAM started so my questions pertain to after I get the water clear again. We have an 8,600 gal above ground vinyl pool. The filter is a pump/sand filter and SWG combo. It’s the Intex QS 2100. I learned after the fact that it’s probably a little too small to generate enough chlorine. It’ll put out 5ppm over a 24hr period. Here’s my questions:
Can I do a combo of the SWG and top off with liquid chlorine to stay at my ideal FC range? My CYA is at 60 right now, so I need to be in the 4-9 range for FC. If I can do a combo method, will that change my targets for CYA/FC? I’d like to run the pump for 12 hours, which would put me around 2.5ppm and then add however much liquid I need to reach my target. Is this doable?
How long do I need to track so I can get a good idea of my chlorine loss? A week? And when do I test that each day? Before sunrise and right before sunset? Sorry if that was in the pool school section. I’ve read so much, it’s all run together.
My husband is the GM for our local water company. He can get HTH, which is 65% liquid chlorine. Is this ok to use? This is not the same thing as the HTH pool products.
I have a TF100 salt test kit for reference. Thanks for any help!
