Hi everyone. We are newer pool owners and will be closing our pool for the first time. We have tried to remove the return jet fittings, but they are not budging what do ever and we do not want to break the pipes inside of the pool wall. So...I have purchased a set of smaller expandable rubber plugs that should fit i inside of the return jets themselves. Has anyone ever tried doing it this way? The pool company that was supposed to have winterized the pool last fall prior to us purchasing the pool did not do it correctly, the jets were not capped off the skimmer was not plugged up and so I doubt the lines were blown out either. We were lucky that nothing got damaged over the winter. They did drain the pump, filter and heater and removed those plugs, and they put on the winter cover. We do live in a more temperate climate so thankfully that was enough, but it does snow here and gets down to freezing a couple of times each wi yet so we want to be sure to protect our pool correctly.
Has anyone tried plugging the return lines with the jests in place and has it worked well for you?
