So we just got our pool completed and I've read pool school and am using pool math to do my calculations. We have a salt water generator and I wanted to also add boric acid to help with PH and general water "feel". We have an 18,000 gallon pool verified by the installer and by using multiple pool size estimates online. For an 18,000 gallon pool it says we needed 13.5 bags of salt to get to 3600 ppm of salt and 43 pounds of boric acid to get to 50ppm of borates. I wanted to play it safe and go below those values as to not over shoot but got high readings of both.
We used 12 bags (40 lb) of pool salt and have a reading of 4300 ppm - the IC40 read 4200 and the test kit 1766 had a 4300ppm as well.
The boric acid I used 35 pounds and am using the test strips for that and after two test strips it looks closer to the 80ppm than the 50ppm.
What am I doing wrong?
FC is currently real high at 12 since I am dialing in the SWGG - ran it for 24 hours at 50% - now I'm running it at 10 hours at 50%.
PH is at 7.2
Are the test strips that bad? Do I need to drain some water and add fresh?
PH is at 7.2
