- May 18, 2015
- 356
- Plaster
- CircuPool RJ-60 Plus
I replaced a Hayward super pump with a Hayward VSP super pump. Last night when finishing up, I just turned on the breaker, made sure the display lit up on the pump, it started to spin up and I then shut it down. No problem.
This morning I’m ready to fire it up and get it programmed. As soon as I turn on the breaker, it trips. I disconnected the load wires from the breaker and it still trips.
If I disconnect the ground wire from the pump, it will not trip. The other end of that ground wire runs directly to the GFCI breaker. That’s the way the original pump was wired.
So basically I only have the ground wire on there and that’s enough to trip the breaker. ???
What am I missing here?
It’s a Hayward SP2603VSP.
