I have a brand new Pentair Intellichlor IC60. The past four evenings have been the first times I've used it. And four evenings in a row I have fired it up after dark at a percentage and duration that, according to Pool Math, should raise FC by 2.5 ppm. But I am getting 1.5 to 1.0 ppm instead. I checked each morning when the sky was still dim and there was no direct sunlight on the pool. Any ideas what might be going on?
Relevant facts
Anything else? Thank you all.
Relevant facts
- Salt level up to 3400 ppm according to my TF Salt bundle. Salt brand was Diamond Crystal "Splash Ready".
- I ran a normal OCLT as recently as 8/12 and lost zero ppm. The water got slightly cloudy after adding salt - noticeable to a TFPer. The TFP Wiki says this can be normal. And indeed after 24 hours it was clear again.
- SWG is run by the 5A relay switch on my brand new Intelliflow 3's I/O board.
- Pump is set to 12.5% speed when SWG is running
- For each of the first three nights, I confirmed that all the correct lights were on the SWG and bubbles were coming out of at least 1 return after the program kicked on at 830 pm. The bubbles "pop" when I hold a lighter to them.
- The 4th night, I didn't start the program until after midnight (thinking perhaps they program had turned off at midnight due to some software bug or user error), so I didn't visually confirm.
- I have not visually confirmed the program is still running just before the programmed end time - not awake yet
- 8/11 into 8/12 - OCLT passed
- 8/13, 8/14, 8/15 - Run IC60 at 60% for 9 hours over night.
- 8/16 - Run at 100% for 5.4 hrs
- Run another OCLT just to rule that out
- Increase flow rate during SWG program (maybe my Chlorine isn't dissolving totally?)
- Could it be wired wrong? LIke maybe 120V is going in, but it's wired for 240?
- Some obstruction in the cell?
- Deceptive PB actually gave me an IC40 but swapped the stickers (kidding...or am I?)
