Hi
As mentioned before, we have a holiday let and have just installed a Wood Burning hot tub. It gets emptied between guests, or once per week, whatever is sooner.
We use Dichlor as a sanitiser. I'm just getting used to testing and adjusting.
Now I'm using Dichlor (was Calcium Hypo before) the pH is nice and stable with TA around 50-60 (I tend to add 40g of TA+ on fill, so depends what the tap water is doing that day).
So I'm testing the water approx 10am and 5pm. Guests tend to use the hot tub in the evening, and sometimes in the afternoons if they have kids.
So I'll top up Dichlor until the FCl is between 3-5. However when I test in the morning, most often it's dropped to about 0.5ppm due to them using it overnight.
Should I worry about this period of it being <1ppm?
I'm not sure what I could do to keep the levels topped up after their use, as I can't really ask them to handle chemicals incase they do something stupid, especially as they'll probably have had a few
. I've got some Trichlor tablets and a floater but was put off by them after reading people saying they will degrade your hottub fibreglass lining, especially if guests play with the dispensor and turn it "up", plus it was making the pH jump about.
Thanks
