HELP! Aquapro 2hp cartridge Filter set-up
Smokenjoe420
Active member
May 27, 2023
28
Clinton, Tn
I just installed and started up my filter system yesterday. Everything appears to be correct and water readings are great. PSI on low speed is about 3psi. When on high speed it is around 12psi. According to the manual I need to clean the filter at 10-12psi. This is a brand new filter and this can't be correct after running for one day. Can someone assist me here?
Clean the filter when the pressure rises by 25% over clean pressure using the same flow rate.
