TA is down to 110 and i've been adding acid in low amounts to keep the ph at 7.2. Still cloudy. I only have a pool robot to run around and keep the precipitate off the floor between brushing. I'm going to clean the filter this evening as its probably pretty full of soda. After brushing or the robot it odesn't seem to be getting any less cloudy. But I guess it will just take some time to filter through.Vacuum the precipitate to waste or through the filter and clean the filter after.
Lower the pH to 7.2.
