jjspence1
3
Houston, TX
Long time lurker first time joiner. Moved around a lot and currently in Houston, TX. Got a particularly troublesome set up with old equipment which I'll end up swapping soon, the previous owner had installed a 2hp fixed pump which does a great job turning over the pool but sucks a bunch of electricity. The Polaris 360 is fun too, taken that little robot apart and swapped parts about 2-3 times in the last year. It does its job when working but I don't see the need for it to be a full time cleaner hence the desire to change to a variable pump soon. I miss my last setup which had an infloor cleaner, can't beat that for easy cleaning I'll testify with my hand on a stack of bibles. Looking forward to learning and helping others if I can.
Welcome 🤗
Here’s all the great links in one
Pool Care Basics
Your signature says you rely on a trichlor feeder for sanitation. This definitely has its drawbacks- namely too much cya in short order.
Check out How to Chlorinate Your Pool for the pros & cons of each type of sanitizer
With tfpc methods & a reliable test kit you’ll be claiming your spot here in no time
How Clear is TFP Clear?
