Hey everyone! I'm a new pool owner with a swamp in my pool
Pool specs: 18x33 oval // ~14,000 gallons
I tested at Leslies before my TF-Pro arrived and their chart showed a CYA of 250 so the pool was drained halfway and refilled twice. The first drain showed CYA of 120 so I drained it again.
Now the TF-Pro results as follows
- TA - 50
- pH - 8.2+(?) I have red/green colorblindness so its hard to tell. Attached photo below
- CYA - ~25 (Black dot is faintly visible at 30)
- Chlorine - 0 or Undetectable with FAS/DPD test
- Calcium - 75
- SLAM
- Increase TA to 100 with 10 lbs of Baking Soda (Generic baking soda from grocery store)
- Decrease pH to 7.6 with pH Down by adding ~2lbs (I bought the Clorox 5lb version)
- Increase FC to 16 with 2 gallons of 10% liquid chlorine (going to get this at Home Depot as its close by)
- Increase CYA to 30-40 with 2-3 pucks of Clorox Trichlor (have some left from previous owner and might as well add some extra FC to SLAM?)
- Calcium - leave it alone since I have vinyl?
- All above additions were from Pool Math
- Whats the minimum wait time before adding pH Down after adding my Baking Soda?
In one of Swim University's videos, it stated wait a minimum of 20 mins after each addition, but other articles say different numbers (1hr, 6hrs, etc) - Is there a ballpark of how much TA/pH increases and decreases with each other? Seems like this is a battle when they're on the opposite ends of each other.
- Anything I should note or look out for while SLAM'ing?
