Hello Everyone as the title says I'm a new pool owner. Purchased the home in February 2011 it came with a 48*16 pool. I posted over at Poolforum and was getting a little help but for some reason now I can't even get to the webpage. Maybe it went offline. Anyhow, this place seems a bit more active so I'm hoping for the best.
I have a Hayward DE 4800 filter. Heyward pump 1081 and a clorinator automatic. A picture below.
I went to a local pool company's (Watson's) Pool School. Was less of a school and more of a sales seminar. I got pool stored there. Ended up with 400 dollars of chemicals I don't know how to use.
25 LB Bag of DE x 2
Pool Perfect Phos-Free 3L x 2
Spring / Fall Phos-free x 2
Pool First Aid 2L x 1
Case Liquid Chlorine x 2
3" Jumbo Slow 7OZ tabs 25LBS x 1
Blast 1lb packets x 3
AquaChek TruTest Digital Test Strip reader
I haven't taken the cover off of the pool yet, I did peak under it and it looks pretty green and water level appears to be 3 inches too low. Under the advice of someone at the "Pool Forum" I took apart my filter and cleaned the very nasty algae from the grids. Currently they are soaking in a trash can with dish liquid.
I am going to put the filter back together today. I have to stop and get some Jack's 327 lube first though. After I put the filter back together what should I do next.
Taking the cover off is a no brainer, but after that?
Should I fill the pool back up to 3/4 covering the skimmer valve first?
Then clean the debris from the pool?
Then add the Liquid Chlorine? How much? While filter is running?
I would love to just have someone come out and open it for me but money is really tight especially after getting pool stored.
Please help me. :?
I'll be happy to take more pictures if needed.
25 LB Bag of DE x 2
Please help me. :?
