Hey all - I've been binge reading the Pool School articles, playing with PoolMath, and already have the app on my phone. This is REALLY great stuff for a first time pool owner like me - thank you! I recently bought a house that has a large plaster pool (20x40 rectangle - est. 36-37k gal) of an unknown age - more detail in my sig. I'm not sure what the previous homeowners did to this poor hole in the ground, but it was an absolute mess when I peeled the cover off it. Dark green, full of algae, no filter, but it had been winterized at some point in the past, as the drain plugs had been pulled, there was antifreeze in the pipes, and a plug in the return.
Long story short, after LOTS of brushing, vacuuming, pool roboting, filter washing, and a round of shock, the pool itself is "clean" of debris and has turned to a cloudy light green color - I can now see about 3 steps instead of none - but it's VERY cloudy, and greenish-blue tinted. I'm awaiting my TF-100 kit (on order!), but got water tested at the store and used the test strips that were left here by the previous owner to try to dial in some idea of where the pool currently is, and here's what I've got:
ph: store=7.2, strip=6.8
TA: store=12, strip=0
CC: store=0.1, strip=(N/A)
FC: store=0.1, strip=0
CH: store=87, strip=80
CYA: store=5.0, strip=0.0
Now, I understand that these values might be seriously out of whack with reality, but while I'm waiting on my TF-100, I wanted to start formulating a loose plan. Obviously things are out of whack, and I've got bulk CYA, baking soda and borax on order, and got some chlorine 8.25%. The big question I have is... what comes first? I know that some of the readings can throw off some of the others, I know that CYA is needed to stabilize the FC, I know that the CH needs to be higher for a plaster pool... so which things should I focus on getting close to acceptable ranges first? Can I adjust CYA and CH at the same time? CYA, CH, and pH? Just trying not to waste anything unnecessarily...
Thanks in advance!
Thanks in advance!
