Hi!!
We have a 18' x 48" Intex pool with SWG and Sand Filter. Pool has been covered since November and water pretty clear since then, with just small bits of debris going in through the small venting cover holes here and there. Sadly, the water looked good all along so I hadn't tested it. I should say the water looked good until we had loads of days of consecutive rain recently (Louisiana) and now the pool cover has loads of algae on it and plenty of water. Peeking under the cover I see there is algae at the bottom of the pool now too. I've been running the SWG now for about 24 hours with what seems like no progress but I think the cover needs to come off so I can stir the algae around from he pool bottom. But, I am so worried about trying to take the cover off and getting extra algae from the cover into the pool. I've got so many questions and I feel like I'm already so behind in getting this cleared up.
1. How do I attack the pool cover algae? I was going to take a shop vac and try to get the heavy water off of it but wondering if I should also put bleach in that water first for some time.
2. Do I keep running the SWG? Add bleach to the pool also? Shock? I've never added anything to the pool other than salt, muriatic acid, or CYA (all as needed) after first setup last summer so I'm so nervous to add in other things and mess it all up worse.
3. It's supposed to rain badly again this coming Friday and Saturday. Do you think I can fix this before then? And then how do I prevent it?
Here are my numbers (yikes, the zeros!!):
H 100
TC 0
FC 0
pH 7.2
Alk 40
CYA 0
Thank you!!
Tara
H 100
TC 0
FC 0
pH 7.2
Alk 40
CYA 0
Thank you!!
Tara
