I am new pool owner so any advice will help! I have heard you can easily/cheaply heat your pool using a submersible pump and black garden hose to run it through to heat and put back in. Can you do that if you have a salt chlorine generator? I didn't know if that would cause any problems running it through a submersible then letting the regular pool pump do its work with the salt generator?
Thank you for your help.
