Hi all - We moved a few years ago into a house with a pool, and have learned quite a bit since then! We live in a warm part of California, and our pool sees 10-12 hours of direct sunlight every day. We've used a solar blanket for the last season and a half, and can consistently keep our in ground pool (18x36') between 88-90 degrees.
Our current blanket is breaking down and needs to be replaced, and we'd like to switch to solar rings to make it easier to get the cover on and off with one person. The added safety of disks vs a blanket should an accidental fall occur is a nice benefit as well. A roller for our current cover isn't an option given the layout of our yard + diving board. That said, I can't find a definitive answer online as to wether the rings are effective at heating up the pool. Some sources say direct sunlight into the pool is more effective, which seems like rings would have a slight advantage over a solar blanket since light can shine into the water through the gaps. On the flip side, those gaps will allow for more evaporation at night. Has anyone done a before/after comparison on heat gain/retention since moving from a solar cover to solar rings?
For what it's worth, I'll be creating the rings myself using a high quality solar blanket and some form of tubing, so I won't need to worry about a lot of the inflation issues I've read about online with the solar rings available in the market today.
