So the time of the season come where there starts being a chill in the air. The wife-y uni asked what about adding a heater. I've done a little research but want the experiences of others.
From what I gather there are several types of heaters. Heat pump heaters, Gas heaters, wood boiler heaters, solar heaters, solvar covers, etc.
Now my setting. inground 35k gallon pool, Pennsylvania, in the summer now it tops out around 83deg; today it is 68deg.
Now I'll ask from the cheapest to the most expensive, who knows it may be the least effective to the most effective.
Solar covers the floating bubble type. do these do anything? At minimum I would expect that these would retain heat in the pool, maybe not raise the pool temperature at all. I also would expect these to be a pain in the but to take on/off and store.
Solar heaters. These could be home brew or manufactured and powered by your pool pump or an external sump pump to circulate just the water through the heater array. Are these effective? I actually have a good southern exposure. These could be placed. I would expect these to actually warm the pool water but not raise it dramatically.
My final option that I see is a heat pump heater. These would be the most reliable but would be expensive to procure, install, and operate but they would work without issue.
Hey if experience of a solar cover and solar heaters could take me to the end of September comfortably then I would be happy. If I need a heat pump that may be a more difficult conversation with the wife.
Hey if this has all been covered before and you want to tell me to use the search function...please give me some key words/user names to narrow down that search!
Thanks.
Thanks.
