[FONT="][FONT="]Automation system alternative?[/FONT][/FONT]
[FONT="][FONT="]My old system had a single speed pump controlled by a mechanical 220V time clock and a fireman’s switch to shut down the heater ahead of the pump. I now have a Pentair Superflo VS pump which doesn’t really need the time clock as it can be programmed directly. I rarely use the heater however I want to protect it from running without the pump engaged and still provide a cool down timing function. Automation systems appear to be expensive and I only need it for this cool down function.[/FONT][/FONT]
[FONT="][FONT="][/FONT]
[/FONT]
[FONT="][FONT="]So...here’s my thought:[/FONT][/FONT]
[FONT="][FONT="]Install a 6 hour spring wound count down timer to control the heater.[/FONT][/FONT]
[FONT="][FONT="]Set the “Quick Clean” function on the pump to run at a sufficient rpm and a duration of 7 hours. (The Quick Clean function overrides all programming until it completes its cycle and then reverts back to the programmed schedule).[/FONT][/FONT]
[/FONT]
[FONT="][FONT="]So my operation to run the heater would be:[/FONT][/FONT]
[FONT="][FONT="]1.Engage “Quick Clean” cycle on pump.[/FONT][/FONT]
[FONT="][FONT="]2.Set spring wound timer to 6 hours (max time setting)[/FONT][/FONT]
[FONT="][FONT="]3.Set thermostat on heater[/FONT][/FONT]
[FONT="][FONT="]This would ensure that if I forget to turn off the heater, it would do so automatically with sufficient cool down time.[/FONT][/FONT]
[/FONT]
[FONT="][FONT="]Thoughts?[/FONT][/FONT]
[/FONT]
[FONT="][FONT="]Thanks[/FONT][/FONT]
[/FONT]
[FONT="][FONT="]Scott [/FONT][/FONT]
[FONT="]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[FONT="]
[/FONT]
